Aller au contenu principal
Changement batterie DualShock 3
Andrew Bookholt
Andrew Bookholt et 7 autres contributeurs
Dernière mise à jour le August 12, 2024
10 minutes
Modérée
Tutoriel vedette
Suivez ce tutoriel pour remplacer la batterie lithium interne des manettes PlayStation 3.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Changement batterie DualShock 3, Coque arrière: étape 1, image 1 de 1
    • Dévissez les cinq vis cruciformes (Phillips) de 7,2 mm qui fixent la coque arrière à la manette.
    I have 2 controllers I'd like to fix, and both have at least one stripped screw in them. Any tips for removing them?
    Joe - Réponse
    For me the PH #0 had too much play. I ended up using the PH #1 which was a perfect fit.
    Yokocapolo - Réponse
  2. Changement batterie DualShock 3: étape 2, image 1 de 1
    • Appuyez sur la coque arrière entre les deux sticks analogiques et soulevez légèrement le bord inférieur pour le séparer du reste de la manette.
    Es ist nicht ganz eindeutig das zwischen den beiden Analog-Sticks gedrückt werden muss. Der gelbe Punkt fällt kaum auf. Ein Bild mit Daumen an dieser Stelle wäre gut oder soooo…
    Tom - Réponse
    it’s not very clear but for this step you need to push where the yellow dot is shown on the picture. it’s rather tough. you kind of have to move the whole back plate a bit for it to work.
    Brandon der Blatter - Réponse
    I’m stuck at this step because I can’t for the life of me undo the clip
    IttyBittyGamerVR - Réponse
    Yeah I’m lost here too. I’m pushing where the dot is but nothing is happening. What am I trying to accomplish by pushing there? Is there a clasp on the inside I’m trying to undo or something? I really don’t want to break the controller by using too much force or opening it the wrong way.
    Could it be that the sixaxis I have is constructed differently? Or is this just a difficult step?
    Joe - Réponse
    Adding: I ended up getting the shell off but ended up breaking off a small piece which I'm guessing was securing the front and back shells together. The trigger buttons and pieces remained intact on one of my two controllers which is what I was worried about, though I did have to fit the small trigger pieces back in.
    The one controller seemed to fit back together just fine without the small piece that broke off, and buttons seemed to feel and work fine too.
    Joe -
    I had to use a small flathead to lever it apart.
    mbelanger - Réponse
  3. Changement batterie DualShock 3: étape 3, image 1 de 2 Changement batterie DualShock 3: étape 3, image 2 de 2
    • Pousser légèrement la coque arrière vers le bord supérieur de la manette pour dégager le bord avant des gâchettes #2.
    • Retirez la coque arrière du reste de la manette tout en faisant attention à ne pas faire sortir les cachettes #2.
    • Si vous avez accidentellement retiré les boutons de la gâchette, nous avons un tutoriel sur les boutons de la gâchette pour les remettre en place.
    the "trigger button guide" link links back to this page :o
    Alexander McMahon - Réponse
    I accidentally popped a trigger off, and both L1 and R1, because I skimmed and didn't read this step. Fortunately it's not hard. The tricky part with the triggers is that there's a little spring on them. You have to press the side of the spring that's pointing away from the trigger against the sloped surface of the controller (look at the other trigger for reference, if you only popped one off). Then you just slide the trigger on until the "handlebar" bits near the center click into place.
    briancaraher - Réponse
    The reset button – a small mostly-rectangular rubberized piece – fell out as I removed the rear cover. It covers the hole near the middle screw and has a post that presses SW1 on the motherboard.
    Fletcher Stern - Réponse
  4. Changement batterie DualShock 3, Batterie: étape 4, image 1 de 1
    • Soulevez la batterie de la carte mère afin de dégager suffisamment d'espace pour accéder au connecteur de la batterie.
  5. Changement batterie DualShock 3: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Déconnectez la batterie de la prise sur la carte-mère avec précaution.
    • Il est souhaitable d'utiliser une pincette de précision antistatique ou des pinces pour saisir le connecteur de la batterie lorsque vous la déconnectez pour la première fois. Ne tirez que sur le connecteur. N'essayez surtout pas de le retirer en tirant sur les fils rouge et noir.
    be careful with the connector, it was hard at the first time to take it away, i was close to break the wire
    Mugen - Réponse
    Where can I purchase an Input Board?
    Cody - Réponse
    To safely remove the connector, you can slide a thin screwdriver inside two slots that can be found on top of the connctor housing (the beige colored one), which allow you to push on the connector. Do this slowly, prying first through one slot, then through the other, until the connector is out. This will allow you to remove the connector without pulling by accident on the wires.
    Adriana Fulgenzi - Réponse
    Thanks Adriana. Good advice. My local battery replacement guy will not touch PS3 controllers.
    DutchAussieProductions -
    Hi Adriana,
    I have to say, that tip really saved me. I was pulling on the wires (this is my first time doing this) and wasgoing nowhere.
    Thank you!
    Michael Vichiola -
    I highly, HIGHLY recommend that if anyone bought the protect toolkit, that they use the SIM bit as that is extremely helpful for this step!
    Michael Vichiola -
    Take note: The PS3 remote controller in this guide has some white plastic spacers shaped like ( and ) on the board which keep the battery from touching the chip. The PS3 remote controller I disassembled has no spacers on the board but rather the board has 6 holes - 4 small square corner alignment holes and two rectangular retaining holes. The battery was an LIP1472 but the battery pack casing had 4 alignment pins and 2 retaining tabs to fit into the board and hold the battery away from the chip. Why does it matter? It may or may not matter, however the fact that all designs include separation indicates that it might matter. Possible reasons are that the battery might touch the chip and cause electrostatic damage, the battery might touch the chip and not allow the chip to dissipate heat properly, or the battery might simply rattle a bit. I can not find any replacement batteries with pins and tabs. It may be necessary to create some standoffs from plastic similar to those shown above and attach to board.
    Warp9pnt9 - Réponse
    My controllers new battery (ordered from ifixit) doesn’t have connectors on it like my dead battery. Help?
    Michael Vichiola - Réponse
    Its literally completely flat (the battery)
    What's the battery's voltage?
    Keith Wucherer - Réponse
    The battery is 3.7 voltage 610 mAH from Sony's LIP1359 battery. Max charging is 4.2 V and 0.4A, but I found a better one from Digikey. It is still required to modify the battery's connector.
    My new battery for the PS3 controller.
    https://www.digikey.com/en/products/deta...
    Michael Marr -
    Yes, yes, yes brilliant suggestion! I broke the wires to the battery trying to wiggle the connector off using needle-nose pliers, but pushing through those slots on the top saved the day even after that little fiasco. Yay.
    Steven Folberg - Réponse
Pour remonter votre appareil, suivez ces instructions en sens inverse.
157 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
20 commentaires
I got the shell separated but unfortunately snapped the lil plastic clip on the rear of the controller's bottom half. a lil super glue and treezers fixed tht up nicely...Thanks for the help
KUDOS to you!!!
Rob (rjmat42)
Robert - Réponse
I have different battery on my second controller, battery itself have pins to connect it with board, no more white plastic holder :/
Raf - Réponse
Try Amazon Cody
linzikerner - Réponse
whats is amazon cody?
Albert Einstein -
Anyone have any idea where I can find the plastic retainers for the battery? I bought the new one, but my old battery has the clips attached. I don't want this thing just jiggling around in there, it'll drive me nuts.
Thanks.
geoquin4 - Réponse
Has anyone tried charging one of these batteries while it's still disconnected from the controller? I wanted to test one of my old ones to see if it still holds a charge or if the circuit board is damaged.
I was considering hooking it to a 5v line on my computer's power supply in series with a resistor or maybe using an old wall adapter.
Scott Stygar - Réponse
Can you transplant the DS3 Battery into a DS4.
Jaccob Miller - Réponse
probably not Jaccob M, as a DS4 controller has more systems such as the lights and the touch pad than the DS3
gnatgnat71 - Réponse
What to do when my controller doesn't charge
Keagen - Réponse
Cut the wires off that connects my batter to the white clip how do I fix reconnect the wires to the clip?
Sabrina Findley - Réponse
Where can one purchase a replacement battery?
Eric Jaeger - Réponse
I have replaced the battery but when plugged in there is no lights coming on :( any idea as to why the controller isn’t charging even with a new battery? I have tried multiple different cables, different USB charging ports and no luck. Maybe I got a bad battery?
Any suggestions?
Ryan Brenner - Réponse
I recommend using Phillips #1 for all Dualshock 3 repairs. #0 and especially #00 have a lot of play with the screws. I nearly badly damaged one of the screws before I switched to #1. It seems to fit almost perfectly. Quite snug. There’s still a tiny wiggle, but only slightly. Hardly at all.
I suggest updating the guides with this information. If anybody has had the same experience as I have and has the ability to edit these guides, I think this modification would help a lot. Also, I’d like to here from anyone else who had the same experience and could second this suggestion.
Sorry for the repost. Just want to put this somewhere it’ll be seen.
Donovan Carlson - Réponse
Good advice !
token -
Have not yet completed the task since I just discovered one of my Dual Shock PS3 Game Controllers no longer charging. However, I was extremely thrilled to find this website as the instructions look super awesome & in my opinion, easy to understand. Therefore, I have saved it to my 'favorites' as I will be definitely be coming back after I purchase the 'battery'. Thanks in advance for your valuable assistance in providing this type of information!
Vincent Carnovale - Réponse
Bonjour et pour avoir les commentaires en français on fait comment ??
Merci
Mih-nhou Petit - Réponse
Essayez ceci, parce qu'il n’existe pas encore de traduction officielle en Français.
A.J. -
My controller stopped working, either plugged in or not so I changed the battery which it had been needing for quite a while and it still does not appear to be charging or communicating with the PS3. I am looking for suggestions on where to go from here.
Jer - Réponse
My Controller contains a plastic cage to hold the battery in place. Also, the circuit board looks a little different from the images above. Mine has metal pins holding the cage and piercing the battery when no cage is used. Anyone else? Where did you find a battery that fits? Normal ones are too large for the cage…
Mark - Réponse
I replaced the battery and when I turned it on it was blinking red for the numbers 1, 3, and 4 the 2 wasn’t blinking and I don’t know what to do
Mark U. - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 67
7 derniers jours : 450
30 derniers jours : 1,780
Total : 206,589
