Aller au contenu principal
HP Envy TouchSmart 15 Fan  Replacement
Ramon Villadonga
Ramon Villadonga et 5 autres contributeurs
Dernière mise à jour le November 23, 2015
10 - 20 minutes
Modérée
You might need to replace the fan if your laptop overheats, or you hear loud grinding noises from inside the case. Alternatively, if you hear no noise from inside the case because the fan is broken.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. HP Envy TouchSmart 15 Fan  Replacement, Battery: étape 1, image 1 de 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Fan  Replacement: étape 2, image 1 de 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Fan  Replacement, Accessory Plate: étape 3, image 1 de 2 HP Envy TouchSmart 15 Fan  Replacement, Accessory Plate: étape 3, image 2 de 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Fan  Replacement: étape 4, image 1 de 3 HP Envy TouchSmart 15 Fan  Replacement: étape 4, image 2 de 3 HP Envy TouchSmart 15 Fan  Replacement: étape 4, image 3 de 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Fan  Replacement, Solid State Drive: étape 5, image 1 de 2 HP Envy TouchSmart 15 Fan  Replacement, Solid State Drive: étape 5, image 2 de 2
    • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
    • After you have removed the screw, the Solid State Drive should lift up.
  6. HP Envy TouchSmart 15 Fan  Replacement: étape 6, image 1 de 2 HP Envy TouchSmart 15 Fan  Replacement: étape 6, image 2 de 2
    • Very carefully, remove the SSD by gently pulling away from the SSD socket.
  7. HP Envy TouchSmart 15 Fan  Replacement, Hard Drive: étape 7, image 1 de 2 HP Envy TouchSmart 15 Fan  Replacement, Hard Drive: étape 7, image 2 de 2
    • Use the plastic opening tool to pry the hard drive away from the board. Notice that there is a slit centered at the back of where the hard drive is sitting. This is where you'll insert the plastic opening tool as shown in the photo. Finally, pry with the plastic opening tool to remove the hard drive.
  8. HP Envy TouchSmart 15 Fan  Replacement: étape 8, image 1 de 2 HP Envy TouchSmart 15 Fan  Replacement: étape 8, image 2 de 2
    • Firmly grasp the connector's base as shown and pull to remove from the hard drive.
  9. HP Envy TouchSmart 15 Fan  Replacement, Back Plate: étape 9, image 1 de 3 HP Envy TouchSmart 15 Fan  Replacement, Back Plate: étape 9, image 2 de 3 HP Envy TouchSmart 15 Fan  Replacement, Back Plate: étape 9, image 3 de 3
    • Remove the highlighted rubber stoppers with a metal spudger as pictured. They should expose a screw that you will need to remove in a later step.
  10. HP Envy TouchSmart 15 Fan  Replacement: étape 10, image 1 de 3 HP Envy TouchSmart 15 Fan  Replacement: étape 10, image 2 de 3 HP Envy TouchSmart 15 Fan  Replacement: étape 10, image 3 de 3
    • Remove plastic cover highlighted. It should expose a screw that you will need in a later step.
  11. HP Envy TouchSmart 15 Fan  Replacement: étape 11, image 1 de 1
    • Remove all highlighted screws with PH 1 screwdriver. These screws are PM 2.0x2.5.
  12. HP Envy TouchSmart 15 Fan  Replacement: étape 12, image 1 de 2 HP Envy TouchSmart 15 Fan  Replacement: étape 12, image 2 de 2
    • Remove all highlighted screws from the battery access area. These are PM 1.5x2.0 screws
    These were very tricky for me, I ended up with one nonfunctional screw, it seemed as if the 00 was a bit too large for the screw.
    Yonatan Abrego - Réponse
    Use the PH0 bit for this step.
    kevinbush85 - Réponse
  13. HP Envy TouchSmart 15 Fan  Replacement: étape 13, image 1 de 1
    • Remove screws highlighted with PH1 screwdriver from accessory plate area.These are PM 2.5x3.0 screws
    • Remove screws highlighted with PH1 screwdriver from accessory plate area. These are PM 2.5x4.5 screws
  14. HP Envy TouchSmart 15 Fan  Replacement: étape 14, image 1 de 3 HP Envy TouchSmart 15 Fan  Replacement: étape 14, image 2 de 3 HP Envy TouchSmart 15 Fan  Replacement: étape 14, image 3 de 3
    • Pry open back plate area with plastic opening tool. The back plate should pry open with relative ease. If you feel some resistance at any point please refer to steps 2-5 because a screw has probably been missed.
  15. HP Envy TouchSmart 15 Fan  Replacement, Fan: étape 15, image 1 de 2 HP Envy TouchSmart 15 Fan  Replacement, Fan: étape 15, image 2 de 2
    • There are 3 screws holding the fan in place. These are PM 2.5x4.5 screws
    What is the fans id number so I can replace it?
    RxMode - Réponse
  16. HP Envy TouchSmart 15 Fan  Replacement: étape 16, image 1 de 2 HP Envy TouchSmart 15 Fan  Replacement: étape 16, image 2 de 2
    • There are 3 strips of tape. Remove them with your hand.
  17. HP Envy TouchSmart 15 Fan  Replacement: étape 17, image 1 de 1
    • Remove the fan by sliding it out and pulling it upwards. Set the fan off to the side to reveal the connector.
    What is the fan partnumber?
    Missan Eido - Réponse
  18. HP Envy TouchSmart 15 Fan  Replacement: étape 18, image 1 de 2 HP Envy TouchSmart 15 Fan  Replacement: étape 18, image 2 de 2
    • Remove the black connector from the white insert shown at the center of the picture just below the fingers pinching the black connector.
    • The connector will come out straight up.
21 autres ont terminé cette réparation.
Ramon Villadonga
Membre depuis le 09/04/15
1 035 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 2-6, Sullivan Fall 2015 Membre de l'équipe USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 membres
10 tutoriels rédigés
13 commentaires de tutoriel
TY. excellent write up =)
Rameez Aftab - Réponse
TY good write up I did not have an SSD drive . Some of the screw locations were slightly different [I suppose they very by configuration].
I meticulously followed your instructions. I did have trouble reconnecting the hard drive but it was my lack of experience and a good magnifying glass. Problem fixed. Fan working great.
Really appreciate your photos and explanation
jkbushtx - Réponse
Excellent directions. Great pictures. Everything was as specified in the instructions. Original fan had a piece of broken plastic in it Removed and reassembled, works great. Make sure flat lead for hard drive is correctly installed.
fischer.jim59 - Réponse
This was seriously better than any YouTube video ever. It worked like a charm period thank you so much.
Ginger Grant - Réponse
Excellent walk thru... best I've ever seen!
Julie Baker - Réponse
Awesome and detailed instructions. Showing exactly where each screw type goes.
Thank you! -Rob Carson
Rob C - Réponse
Thank you! -Rob C
Rob C - Réponse
A great writeup, worked perfectly.
The rubber feet on my laptop had quite a lot of glue on, so taking those off took some doing.
It may be worth mentioning that at step 15 (backplate removal), you need to be careful with the HDD flexible cable, and know how to remove and replace afterwards. Might seem obvious, but this threw me a bit as a newbie, as it is looped around the backplate. :)
cbrowne91 - Réponse
Absolutely outstanding directions. I have never serviced a laptop before yet I was able to follow these detailed directions and replace a fan unit myself. Thank you so much for taking the time to write this guide.
Michael M - Réponse
Great work thanks
Leigh - Réponse
im am a fan now too
Revo - Réponse
Really great write up. Especially given that there is so much confusion around HP Envy notebooks, this exactly what I was looking for my HP Envy 15 TS. Very meticulously written. This is lot more convenient than a video where restarts rewinds etc are a chore. Thank you.
batlanki - Réponse
What fan do i need to order to replace mine. This model etc.
RxMode - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 45
Total : 14,149
