Aller au contenu principal
Lenovo Thinkpad T450 RAM Replacement
Justin Ogihara
Justin Ogihara
Dernière mise à jour le April 12, 2025
10 - 20 minutes
Modérée
The random access memory (RAM) module is an essential component to a functioning and working laptop. The RAM is a component that stores short-term memory and is completely different from other memory modules or storage devices in a laptop, such as a SSD or a hard drive. Some boot-up procedures and programs may be stored on the RAM when a device is turned on.
If you find that your device is slower than usual or if it isn’t properly booting, it may be time to replace the RAM. Follow these instructions to replace the RAM in your Lenovo ThinkPad T450.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Lenovo Thinkpad T450 RAM Replacement, External Battery: étape 1, image 1 de 3 Lenovo Thinkpad T450 RAM Replacement, External Battery: étape 1, image 2 de 3 Lenovo Thinkpad T450 RAM Replacement, External Battery: étape 1, image 3 de 3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 RAM Replacement, Back Cover: étape 2, image 1 de 1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 RAM Replacement: étape 3, image 1 de 3 Lenovo Thinkpad T450 RAM Replacement: étape 3, image 2 de 3 Lenovo Thinkpad T450 RAM Replacement: étape 3, image 3 de 3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 RAM Replacement, RAM: étape 4, image 1 de 2 Lenovo Thinkpad T450 RAM Replacement, RAM: étape 4, image 2 de 2
    • Lift up the black piece of tape and remove it to uncover the RAM sticks underneath.
  5. Lenovo Thinkpad T450 RAM Replacement: étape 5, image 1 de 2 Lenovo Thinkpad T450 RAM Replacement: étape 5, image 2 de 2
    • Using your fingers, push the two clips securing the RAM away from each other to release the RAM.
    • The RAM stick should pop up at a 30 degree angle.
    • Remove the RAM stick from the device.
    • Repeat this step for any additional RAM sticks.
3 autres ont terminé cette réparation.
Justin Ogihara
Membre depuis le 09/18/17
29 190 Réputation
52 tutoriels rédigés
Équipe
EDU Team Membre de l'équipe EDU Team
Staff
7 membres
772 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 84
Total : 3,115
