Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 12 tutoriels qui comprennent cette étape.
Traduction de l’étape 7
Étape 7
Use your Torx driver to remove the two outer 6.5 mm screws securing each of the two display brackets to the upper case (4 screws total).
- | [* red] Remove the two outer 6.5 mm Torx screws securing each of the two display brackets to the upper case (4 screws total). |
+ | [* red] Use your Torx driver to remove the two outer 6.5 mm screws securing each of the two display brackets to the upper case (4 screws total). |
+ | [* icon_note] Mid 2009 models require a T6 Torx driver, while Mid 2010 models require a T8. |
