Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Traduction de l’étape 5
Étape 5
Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
Repeat the previous process to remove the other ribbon cable.
- | [* red] Place a plastic opening tool under the |
+ | [* red] Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports. |
[* black] Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port. | |
[* black] Repeat the previous process to remove the other ribbon cable. |
