Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Modèle A1993. Mise à jour de 2018 du Mac mini Apple. Processeurs disponibles : Intel Core i3 quad-core à 3,6 GHz, Intel Core i5 hexa-core à 3,0 GHz et Intel Core i7 hexa-core à 3,2 GHz.
Mac Mini RAM Upgrade Early 2020
Hey
Please don’t mind me asking - is it possible to upgrade the RAM in the new version of the Mac Mini from March 2020 as described for the 2018 Model? It would think so, but would like to make sure for my purchase.
Cheers
Répondre à cette question J'ai le même problème
Indice 17
5 commentaires
What are the specifications of memory on the MacMini 2020?
par Partager
@bknj - DDR4 PC4-21300 2666 MHz 260 pin SO-DIMM's (max of two DIMM's) Review this guide Remplacement de la mémoire (RAM) du Mac mini fin 2018
par Partager
Thanks for the reply. Crazy how much Apple charges for RAM.
par Partager
Based off of images on Apple’s website for the Early 2020 Mac mini Overview and the statement on the he Apple Web site that the Mac Mini will use SO-DIMM RAM I would say yes, the memory is upgradable.
par Partager
Does anybody know is this memory compatible with mac mini 2020
Kingston Impact SO-DIMM 16GB DDR4 HX426S15IB2/16
par Partager
Ajouter un commentaire
4 Réponses
Réponse la plus utile
While Apples Mac Mini RAM guide implies its not upgradable Upgrade or install memory in your Mac mini
Both the 2018 & 2020 have serviceable RAM as seen here in this guide: Remplacement de la mémoire (RAM) du Mac mini fin 2018.
Apple has only upgraded the CPU, RAM and Storage options in 2020 not altering the basic system design.
Indice 7
8 commentaires:
I did one last month. 32GB Just make sure the RAM is fully seated so you don't have to open it twice like I did.
par Partager
Is the crucial ddr4 2666 32gb SODIMM the correct ram to instal in the Mac mini i7 2020? Iv been trying to find out for a while. Thanks
par Partager
Best to contact Crucial to ask them. Crucial
par Partager
Will Kingston Technology HyperX Impact 16GB 2666MHz DDR4 CL15 260-Pin SODIMM Laptop Memory (HX426S15IB2/16) be compatible with the mac mini 2020? I am thinking to buy one.
par Partager
On the market there are suitable memories with different speeds: 2666Mhz and also 3200Mhz. Does it make sense to use the 3200 Mhz ones on this Mac 2020 model?
par Partager
Voir 3 commentaires en plus
Be aware you will be really disassembling the Mac Mini to get to the Ram slots. After you remove the black plastic cover and get to the Torx security screws be careful not to mix them as there are different sizes for the screws.
Finally when you go to insert the Ram take care to ensure the Ram is not inserted at an angle and is seated completely in the Ram slot. My roommate had to reopen his because one of the Ram cards wasn't fully seated in it's slot.
Indice 2
I did a RAM upgrade on a Mac Mini Late 2018. Take it slow and meticulously and make sure you follow the instructions. When you re-assemble the Mac, from the very first step when you insert the RAM and especially when you reconnect the cables make sure things are seated correctly and firm. I did not connect the fan perfectly and was greated with a very funny sound. It is very easy provided you have the correct screwdriver and good tweezers.
Indice 0
What are the mac mini 2020 SSD RAM upgrade options? How to do mac mini 2020 memory upgrade?
Indice 0
2 commentaires:
@shopinbrand
What your asking doesn’t make sense A ssd is a storage medium and ram memory is used for multitasking. If you haven’t taken a Mac mini 2020 apart make sure you are ready Have a sheet of paper and draw the mini out so you can lay the screws in the correct locations
As for what ram to buy it is clearly mentioned above several times You want good quality first run ram, NOT value ram you need 2666mhz sodim ram for the mini
par Partager
So the RAM in the new mac mini can be upgraded after purchase? I need to buy one now for work, and can't wait the 3-4 weeks for the delivery of the Mac Mini with 16GB.
par Partager
Ajouter une réponse
Lennart sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 17
30 derniers jours : 55
Total : 55,356
