Aller au contenu principal
Remplacement de l'écran LCD de l'iPad Mini GSM
Andrew Optimus Goldheart
Andrew Optimus Goldheart et 6 autres contributeurs
Dernière mise à jour le January 27, 2019
45 minutes - 3 heures
Difficile
Utilisez ce tutoriel pour remplacer un écran LCD fissuré ou endommagé.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Vidéo d'introduction
  1. Remplacement de l'écran LCD de l'iPad Mini GSM, Chauffer un iOpener: étape 1, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM, Chauffer un iOpener: étape 1, image 2 de 2
    • Nous recommandons de nettoyer le micro-ondes avant de commencer. D'éventuels restes au fond risquent d'adhérer à votre iOpener.
    • Placez l'iOpener au centre du micro-ondes.
    • Pour les micro-ondes à plateau tournant : assurez-vous que le plateau tourne bien. Si votre iOpener reste coincé, il risque de surchauffer et de brûler.
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - Réponse
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - Réponse
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - Réponse
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - Réponse
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - Réponse
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - Réponse
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - Réponse
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - Réponse
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - Réponse
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - Réponse
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - Réponse
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - Réponse
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - Réponse
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - Réponse
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - Réponse
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - Réponse
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - Réponse
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - Réponse
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - Réponse
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - Réponse
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - Réponse
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - Réponse
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - Réponse
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - Réponse
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - Réponse
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - Réponse
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - Réponse
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - Réponse
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - Réponse
    Can’t you just use a hair curler instead?
    Aspect22 - Réponse
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - Réponse
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    Dan Smith - Réponse
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    Dan Smith - Réponse
    My iOpener got damaged at the first heating (30 s @ 800 W). The bag got a little melted hole where the liquid came out and a little melted area. I used a combination oven (normal heat and microwave) in microwave only mode. It has a metal grill where the iOpener was placed on. I suppose the metal grill concentrates the microwaves at some points and there the bag melted?
    K. Fe - Réponse
  2. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 2, image 1 de 1
    • Chauffez l'iOpener pendant trente secondes.
    • En fonction de la puissance de votre micro-ondes, la durée de chauffage nécessaire variera. L'iOpener est assez chaud lorsqu'il est un peu trop chaud pour le toucher confortablement.
    • Comme l'iOpener refroidit au cours de la réparation, rechauffez-le à nouveau au micro-ondes, mais ne dépassez pas les trente secondes à chaque fois.
    • Faites attention de ne pas surchauffer l'iOpener pendant la réparation. En cas de surchauffe, l'iOpener risque d'exploser. Ne le chauffez pas au-dessus de 100°C (212°F).
    • Ne touchez jamais l'iOpener s'il vous paraît gonflé.
    • Si le milieu de l'iOpener est encore trop chaud au toucher, continuez à l'utiliser jusqu'à ce qu'il soit assez froid pour le chauffer à nouveau. Un iOpener correctement chauffé devrait rester chaud pendant environ 10 minutes.
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - Réponse
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - Réponse
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - Réponse
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - Réponse
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - Réponse
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - Réponse
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - Réponse
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - Réponse
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - Réponse
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - Réponse
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - Réponse
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - Réponse
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - Réponse
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - Réponse
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - Réponse
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - Réponse
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - Réponse
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - Réponse
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - Réponse
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - Réponse
    I had a rotating plate microwave for my repair, and heating the iOpener 30-40 seconds worked plenty well for me.
    Ciarán - Réponse
    I tried 600W microwave for 30 sec and it was nicely warm, did nothing on iPad. Added 10 more sec, bit warmer, another 20 sec and it was finally a bit hot to hot in the hand - but still didn't do anything on iPad. I switched to a hair dryer as I used to work with it before, while being a bit sad about not using this brand new iOpener tool. And I found it short on 12.9 iPad anyway, maybe next time.
    Liibo - Réponse
  3. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 3, image 1 de 1
    • Sortez l'iOpener du micro-ondes en le tenant par l'une des deux extrémités plates, car le centre de l'outil risque d'être brûlant.
    • L'iOpener sera très chaud, alors soyez prudent en le manipulant. Utilisez une manique si nécessaire.
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - Réponse
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - Réponse
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - Réponse
    This thing melts when placed up side down in the microwave…
    Mark - Réponse
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - Réponse
  4. Remplacement de l'écran LCD de l'iPad Mini GSM, Méthode alternative pour chauffer un iOpener: étape 4, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM, Méthode alternative pour chauffer un iOpener: étape 4, image 2 de 2
    • Si vous n'avez pas de micro-ondes, suivez cette étape pour chauffer votre iOpener dans de l'eau bouillante.
    • Remplissez une casserole ou une poêle avec suffisamment d'eau pour immerger complètement un iOpener.
    • Faites chauffer l'eau jusqu'à ébullition. Puis éteignez le feu.
    • Placez un iOpener dans l'eau chaude pendant 2 à 3 minutes. Assurez-vous que l'iOpener est complètement immergé dans l'eau.
    • Utilisez des pinces pour extraire l'iOpener chauffé de l'eau chaude.
    • Séchez soigneusement l'iOpener avec une serviette.
    • L'iOpener sera très chaud, veillez donc à ne le tenir que par les languettes aux extrémités.
    • Votre iOpener est prêt à être utilisé ! Si vous devez réchauffer l'iOpener, portez l'eau à ébullition, éteignez le feu et placez l'iOpener dans l'eau pendant 2 à 3 minutes.
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - Réponse
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - Réponse
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - Réponse
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - Réponse
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - Réponse
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
    add a little basil and oregano on the pan peanuts cashews walnuts and bam it pops right off
    david pride - Réponse
    It's more 3 minutes than 2 minutes in hot water, in 2 minutes it's not getting hot enough I think. I used the combo iOpener + hair dryer for about 2 minutes and I could then insert a first opening pick easily. The first opening pick is the trickiest step, then if you go slowly and with patience around the screen with other opening picks, it works well.
    vincent becker - Réponse
  5. Remplacement de l'écran LCD de l'iPad Mini GSM, Panneau frontal: étape 5, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM, Panneau frontal: étape 5, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM, Panneau frontal: étape 5, image 3 de 3
    • Si votre écran est fissuré, et afin de prévenir une nouvelle casse ou une blessure pendant la réparation, recouvrez de ruban adhésif toute la vitre de votre iPad.
    • Placez des bandes superposées de ruban adhésif transparent sur l'écran de l'iPad jusqu'à ce qu'il soit entièrement recouvert.
    • Cela permettra de ne pas faire tomber les éclats de verre et de garder une certaine stabilité lorsque vous ferez levier et enlèverez l'écran.
    • Faites de votre mieux pour suivre le reste du tutoriel tel que décrit. Cependant, une fois que le verre est cassé, il continuera sûrement à craqueler et vous devrez peut-être utiliser un outil en métal pour dégager les éclats de verre.
    • Portez des lunettes de sécurité pour protéger vos yeux et faites attention de ne pas endommager l'écran LCD.
    In case of broken glass, here are some hints:
    - I prefer 3M "3350" tape; a metalized polypropylene tape with an acrylic adhesive. It's a very thin, silvery HVAC tape, not your standard duct tape.
    - Test your tape to make sure it sticks really well to the glass.
    - Use isopropyl alcohol on a paper towel to remove fingerprints and other dirt to help the tape stick to the screen.
    - Use the widest tape you can find, and apply it evenly, without trapping bubbles, without crinkles: This greatly improves your chance of success with the suction cup later.
    - Cut tape pieces long enough and go over the (rounded) edge; afterwards carefully run a scalpel alongside the edge (between bezel and glass) to trim off any excess.
    - Don't overlap edges of the tape: butt-join them instead.
    - If needed: repeat in other direction.
    - If needed: Cut square piece of tape (size of suction cup) and place it where you want to lift the glass, so that the suction cup doesn't cover any butt-joins.
    Good luck, you brave person!
    volty - Réponse
    This is the second broken screen I’ve fixed. Overlapped package tape carefully stuck to the glass and trimmed to the edges will contain most of the shards. I found that a hair dryer works for softening the glue. After getting under an edge with the suction cup I carefully followed the opening sequence using a combination of plastic picks and a single edge razor blade to get under the small pieces. It was slow going with lots of reheating with the dryer (about 45 minutes), but the taped glass came off without glass everywhere.
    Bill Roughen - Réponse
  6. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 6, image 1 de 1
    • En le manipulant par le attaches de chaque côté, placez l'iOpener chauffé sur le côté de l'iPad à gauche du bouton home.
    • Laissez l'iOpener agir pendant environ cinq minutes pour ramollir l'adhésif sous le verre.
    I worked at it for over 2 hours before deciding to microwave the opener for 45 seconds at a time. That seemed to do the trick.
    jaromhyde - Réponse
  7. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 7, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 7, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 7, image 3 de 3
    • Placez soigneusement une ventouse à mi-hauteur du côté chauffé.
    • Assurez-vous que la ventouse adhère à l'écran sur toute sa surface pour obtenir un joint étanche.
    • Tout en maintenant l'iPad enfoncé d'une main, tirez sur la ventouse pour séparer légèrement la vitre du panneau frontal de la coque arrière.
    • Veillez à soulever le vitre de juste ce qu'il faut pour insérer un médiator, car vous risqueriez de la briser en soulevant trop.
    This step is totally pointless if you have a shattered screen. The suction cup is rendered useless. Any tips on what to do if you can't get any suction due to a shattered screen?
    robloomis - Réponse
    just pick out the glass shards if it is cracked that bad you are better off scrapping the digitizer
    echow2001 -
    for shattered screens I cover the screen with tape. I find packing tape works best for me.
    George - Réponse
    I had a second suction cup - one on the glass and one on the aluminum - and the heated gap opened easily.
    Karl Harnish - Réponse
  8. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 8, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 8, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 8, image 3 de 3
    • Tout en tenant le verre avec la ventouse, faites glisser la pointe d'un médiator dans l'espace entre la vitre et le reste de l'iPad.
    • N'insérez pas la pointe plus profondément que le cache noir sur le côté de l'écran. Aller trop loin peut endommager l'écran LCD.
    • Tirez sur la ventouse pour ouvrir le joint d'étanchéité sous vide et retirez la ventouse de l'écran.
    you have to pull up on the suction cup harder than you might be comfortable with!
    jfaulks1 - Réponse
    thanks jfaulks1 (I did not copy and paste lol)
    iliketrains kid - Réponse
  9. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 9, image 1 de 1
    • Refaites chauffer et Reposez l'iOpener.
    • Veillez à ne pas surchauffer l'iOpener pendant la procédure de réparation. Attendez toujours au moins dix minutes avant de réchauffer l'iOpener.
    • Laissez reposer pendant quelques minutes pour chauffer le bord gauche de l'iPad.
  10. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 10, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 10, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 10, image 3 de 3
    • Placez un deuxième médiator à côté du premier et faites-le glisser le long de l'iPad, en décollant l'adhésif au fur et à mesure.
    • Si, au long du reste de la procédure, vous rencontrez une grande résistance en faisant glisser vos médiators sous le verre, arrêtez et réchauffez la section sur laquelle vous travaillez. Forcer sur les médiators risque de briser le verre.
  11. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 11, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 11, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 11, image 3 de 3
    • Continuez à déplacer le médiator vers le bas de l'écran pour détacher l'adhésif.
    • Si le médiator reste bloqué dans l'adhésif, faites-le tourner le long de l'iPad, en continuant à décoller l'adhésif.
  12. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 12, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 12, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 12, image 3 de 3
    • Prenez le premier médiator que vous avez inséré et faites-le glisser vers le coin supérieur de l'iPad.
    • Si vous pouvez voir la pointe du médiator à travers la vitre, ne paniquez pas, tirez-le juste un peu. Tout se passera certainement bien, mais évitez, car vous pouvez mettre ainsi de l'adhésif sur l'avant de l'écran LCD et c'est difficile à nettoyer.
  13. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 13, image 1 de 1
    • Refaites chauffer l'iOpener et placez-le sur le bord supérieur de l'iPad, sur la caméra frontale.
    • Veillez à ne pas surchauffer l'iOpener pendant la procédure de réparation. Attendez au moins dix minutes avant de réchauffer l'iOpener.
    • Si vous avez un iOpener flexible, vous pouvez le plier pour chauffer le coin supérieur gauche et le bord supérieur en même temps.
    I left my iOpener on the bezel the entire time I slid picks in. worked great
    jfaulks1 - Réponse
  14. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 14, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 14, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 14, image 3 de 3
    • Faites glisser le médiator autour du coin supérieur gauche de l'iPad pour séparer l'adhésif.
    Gezz this is though! Cracked the glass while replacing it.
    Padraic Hoselton - Réponse
    :( sad (rip glass lol)
  15. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 15, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 15, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 15, image 3 de 3
    • Faites glisser le médiator le long du bord supérieur de l'iPad, en vous arrêtant juste avant d'atteindre la caméra.
    • La troisième image montre l'emplacement de la caméra frontale et de son boîtier dans l'iPad.
    • Évitez de faire glisser le médiator sur la caméra avant, sinon vous risquez de mettre de l'adhésif sur la lentille ou d'endommager la caméra. Les étapes suivantes détaillent la façon d'éviter d'endommager la caméra frontale.
  16. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 16, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 16, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 16, image 3 de 3
    • Tirez légèrement sur le médiator et faites-le délicatement glisser le long de la zone de la caméra frontale.
  17. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 17, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 17, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 17, image 3 de 3
    • Laissez le médiator dans l'iPad juste après la caméra frontale.
    • Prenez un deuxième médiator et insérez-le à gauche de la caméra, là où le premier médiator était. Faites-le glisser vers le coin pour décoller complètement tout adhésif restant.
    • Laissez le deuxième médiator en place pour éviter que l'adhésif dans l'angle recolle en refroidissant.
  18. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 18, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 18, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 18, image 3 de 3
    • Insérez le médiator précédent plus profondément dans l'iPad et faites-le glisser depuis la caméra vers le coin.
    Shattered my screen pretty bad here, making it so that whenever I continued to move the pick the glass separated and I couldn’t continue moving it. Be VERY gentle moving the pick; almost no force is required.
    Jasper Holden - Réponse
  19. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 19, image 1 de 1
    • Laissez les trois médiators dans les coins de l'iPad afin d'empêcher toute nouvelle adhérence de l'adhésif du panneau frontal.
    • Réchauffez l'iOpener et placez-le sur le côté long restant de l'iPad, le long des boutons de volume et de verrouillage.
  20. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 20, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 20, image 2 de 2
    • Faites glisser le médiator droit supérieur autour du coin pour décoller complètement le bord supérieur du verre.
    • Laissez ce médiator en place pour éviter que l'adhésif recolle et prenez un nouveau médiator pour l'étape suivante.
  21. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 21, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 21, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 21, image 3 de 3
    • Insérez un nouveau médiator et faites-le glisser jusqu'au milieu du bord droit de l'iPad, en décollant l'adhésif au fur et à mesure.
  22. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 22, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 22, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 22, image 3 de 3
    • Continuez à faire glisser le médiator vers le bas de l'iPad, en décollant l'adhésif.
  23. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 23, image 1 de 1
    • Laissez les médiators en place et refaites chauffer l'iOpener.
    • N'oubliez pas de ne pas surchauffer l'iOpener – pas plus d'une fois toutes les dix minutes.
    • Posez l'iOpener chauffé sur la zone du bouton home et laisse-le agir pendant quelques minutes pour ramollir l'adhésif sous le verre.
  24. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 24, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 24, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 24, image 3 de 3
    • Faites glisser le médiator inférieur gauche vers le coin inférieur gauche pour couper l'adhésif dans ce coin.
    • Laissez-y le médiator. N'allez pas plus loin et ne retirez pas le médiator de l'iPad.
    • Il y a un certain nombre de choses à éviter sous la vitre inférieure, alors étudiez attentivement la troisième image :
    • Antennes
    • Emplacement du bouton home
    • Nappe de la vitre tactile
    • Les étapes suivantes vous diront où il faut travailler pour éviter d'endommager ces composants. Ne faites chauffer que les endroits indiqués.
  25. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 25, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 25, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 25, image 3 de 3
    • Laissez le médiator de la dernière étape en place pour éviter que l'adhésif recolle.
    • Faites délicatement glisser un nouveau médiator par-dessus l'antenne gauche et arrêtez-vous avent le bouton home.
    • Faites glisser simplement le médiator depuis bord extérieur vers le centre de l'iPad. Ne le déplacez pas vers le bord extérieur, car dans ce sens, vous endommageriez l'antenne.
    • Si vous devez passer plusieurs fois, retirez le médiator et réinsérez-le sur le bord extérieur et faites-le glisser vers l'intérieur.
    • Laisser les médiators en place avant de poursuivre.
  26. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 26, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 26, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 26, image 3 de 3
    • Insérez la pointe d'un dernier médiator à côté de celui de l'étape précédente et faites-le glisser sous le bouton home.
    • Arrêtez à environ 2,5 cm du côté droit pour éviter de couper la nappe de la vitre tactile.
    • Insérez le médiator un peu plus profondément et retournez vers le bouton home.
    • Encore une fois, assurez-vous de faire seulement glisser le médiator vers le centre de l'iPad lorsqu'il est complètement inséré. Sinon, vous risquez d'endommager l'antenne sous le verre.
  27. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 27, image 1 de 1
    • Réchauffez et reposez l'iOpener sur la partie supérieure du joint de l'iPad.
  28. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 28, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 28, image 2 de 2
    • Faites très attention pendant cette étape. Prenez votre temps et assurez-vous que l'adhésif est chaud et mou, et que vous avez coupé tout l'adhésif avec un médiator. N'ayez pas peur d'arrêter et de refaire chauffer.
    • En haut de l'iPad en face du bouton home, vous devriez avoir un médiator logé dans chaque coin. Faites-les pivoter pour soulever légèrement le verre et séparer ainsi le reste d'adhésif le long des quatre bords.
    • Si vous rencontrez une grande résistance, arrêtez de pivoter. Laissez les médiators en place, refaites chauffer et reposez l'iOpener sur les zones problématiques, avant d'y insérer un médiator une fois de plus.
  29. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 29, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 29, image 2 de 2
    • Soulevez lentement et délicatement pour détacher l'adhésif le long du bord inférieur.
    Really, add a few more pics and a few more picks, see how long and difficult you can make this guide. 26 steps to get the top screen off is ridiculous.
    B. A. Computer Services - Réponse
    Not ridiculous for those of us who do not run a computer service company. Heck, I even read your comment hoping for more information.
    Karl Harnish -
  30. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 30, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 30, image 2 de 2
    • Une fois que tout l'adhésif a été enlevé, tournez la vitre de l'écran comme une page d'un livre et posez-la sur votre plan de travail.
    • Si vous souhaitez remonter votre panneau frontal, vous aurez besoin de remplacer l'adhésif de l'écran. Consultez notre tutoriel de pose d'adhésif d'écran pour appliquer une nouvelle couche d'adhésif et refermer votre appareil.
    I recommend wearing latex gloves or be sure not to put too many finger prints on the front or back of this front glass when lifting it or completing the remainder of the steps. I made this mistake and upon installing the new LCD and putting the iPad back together I realized that I left a few finger prints on the inside of the front glass. After re-securing the adhesive strips putting the iPad back together there are now unremovable fingerprints visible when the LCD is turned off. Just a recommendation on the gloves or be sure to wipe both sides of the front glass clean before putting all back together.
    Christian Screen - Réponse
  31. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 31, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 31, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 31, image 3 de 3
    • Le boîtier de la caméra frontale peut rester accroché au panneau frontal. Décollez le boîtier et placez-le sur la caméra pour la protéger.
    • Faites pivoter le boîtier de la caméra sur un bord pour le libérer de l'adhésif et retirez-le du panneau frontal.
    • Remettez le boîtier de la caméra à sa place dans la coque arrière.
    this didn’t happen to me BUT the glue was still sticking to the top of the glass because one pick had gone OVER the glue and the other under, so I had to pull the glue off and cut it with scissors
    jfaulks1 - Réponse
    OK this was glue, it was the tape from step 35!
    jfaulks1 - Réponse
  32. Remplacement de l'écran LCD de l'iPad Mini GSM, Ensemble LCD: étape 32, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM, Ensemble LCD: étape 32, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM, Ensemble LCD: étape 32, image 3 de 3
    • De petits morceaux de mousse autocollante recouvrent les vis droites supérieures et inférieures, fixant l'écran LCD à la coque arrière.
    • Utilisez une pincette pour décoller et enlever le morceau rectangulaire de mousse recouvrant la vis supérieure droite du LCD.
    • Retirez le morceau triangulaire de mousse recouvrant la vis inférieure droite du LCD.
  33. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 33, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 33, image 2 de 2
    • La vis en haut à gauche du LCD peut être recouverte d'un ruban adhésif venant du panneau frontal.
    • Dans ce cas, utilisez l'extrémité plate d'un spudger pour tirer le ruban vers le haut et à l'extérieur, accédant ainsi à la vis en dessous.
  34. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 34, image 1 de 1
    • Retirez les quatre vis cruciformes #000 de 3,9 mm fixant l'écran LCD à la coque arrière.
    In my case the 4 screws are not the same. One is 4mm, and 3 of 3.5mm, or better 2 x 3.5mm and one 3.45mm. I put the longest one at the left edge at left of the LCD flat cable.
    mitja
    Mitja Jankovic - Réponse
    Hi Mitja. I just checked the measurements with an electronic digital caliper. I got 3.9 mm for all four screws. Are you sure it was the same model? Thanks.
    Walter Galan -
    The top left screw is longer than the other 3 - iPad mini Retina Wi-Fi.
    sandro - Réponse
    On mine the top right screw is longer
    oliver - Réponse
    top right is longer on an ipad mini 2 retina wifi 32GB
    sagert - Réponse
    ipad mini wifi no screws are longer
  35. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 35, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 35, image 2 de 2
    • Utilisez une pincette pour décoller le petit morceau de bande adhésive reliant le châssis du LCD au haut-parleur droit.
    I wonder what does this sticker stands for…
    K8L - Réponse
  36. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 36, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 36, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 36, image 3 de 3
    • Une mince bande de mousse autocollante sur le cadre du LCD recouvre une bande d'adhésif reliant l'écran LCD au panneau en dessous. Pour continuer, vous devrez déchirer et décoller un peu cette bande de mousse pour accéder à l'adhésif caché en dessous.
    • Utilisez une fine pincette pour tirer le haut de la bande de mousse entourant l'écran LCD.
    • Veillez à ne pas toucher l'écran LCD avec la pincette, car vous risquez de l'endommager.
    • Utilisez la pincette pour décoller le ruban de mousse pour accéder au haut de l'écran LCD.
  37. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 37, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 37, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 37, image 3 de 3
    • Insérez la pointe d'un spudger entre le châssis du LCD et la bande adhésive sur le dessus de l'écran LCD.
    • Faites glisser le spudger le long de l'espace entre le châssis LCD et la bande adhésive, en décollant la bande du châssis du LCD.
    I finished a successful replacement of my screen following these instructions. Thanks.
    Step 36 (remove tape from LCD perimeter), however, seems unnecessary. I ended up spending a lot of time separating the tape from the LCD frame only to discover it was not necessary for steps 37-44 and actually made things really difficult for step 45-46 (removing the tape near the speakers). Finally, steps 45-46 can be skipped since it is much easier to remove this tape once you flip the LCD over (Step 55).
    Kenneth Snyder - Réponse
  38. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 38, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 38, image 2 de 2
    • L'écran LCD est collé à la plaque de protection métallique du LCD, derrière celle-ci, le long des bords supérieur, gauche et droit. Afin de décoller cet adhésif en toute sécurité, vous utiliserez un médiator pour déplacer plusieurs fois l'écran LCD de quelques millimètres de gauche à droite.
    • Insérez un médiator dans l'espace entre l'écran LCD et la coque arrière, près du haut du côté gauche de l'écran LCD.
    • Inclinez légèrement le médiator pour l'éloigner de l'iPad, juste assez pour élargir l'espace entre l'écran LCD et la coque arrière.
    I found a very simple method for removing the LCD from the metal shield. Slightly lift one of the top corners and insert a 1' piece of fishing line. Insert the line under the other top corner placing the length between the LCD and shield. Once in place, gently pull each end toward the bottom of the LCD breaking the adhesive as you go. This will make things much easier than using the picks and possibly breaking the LCD.
    bababooey - Réponse
    The fishing line trick is amazing… although i had already broken the LCD when i saw that comment. Good Learn!
    Brandon Lukasik - Réponse
    This step is what destroys my LCDs :(
    Dan Harris - Réponse
    Just destroyed my LCD as well. A red warning remarking is missing here! The LCD assembly is very fragile an cannot be bent, even slightly!!
    brauliox - Réponse
    I have broken about 10 of the 50 or so iPad minis that I have repaired. I always try to have a LCD on hand. I’ll have to try the fishing line trick!
    northstar - Réponse
    I also recommend doing step 45 first (removing the two pieces of foam tape at the bottom).
    northstar - Réponse
    I was able to do this the first time w/out damaging the LCD simply by following the instructions to the letter, slowly and carefully. The only thing I did differently was to follow Northstar’s instructions to remove the two pieces of tape at the bottom of the LCD before beginning.
    Jenny Lawson - Réponse
    I found a good way to remove the LCD without breaking it. Once you finish to clean up around the LCD just lift a bit one of the white metal backing plate and insert in the gap a plastified playing card under le LCD and slowly make your way to the center of the LCD. Repeat on the other side and the LCD will lift up intact.
    lemerise - Réponse
    nothing Brocken after
    (I did not read the comments before doing it lol)
  39. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 39, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 39, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 39, image 3 de 3
    • Insérez le médiator à trois endroits de plus sur le côté gauche de l'écran LCD et inclinez-le à chaque fois, pour faire glisser l'écran LCD sur le côté droit de la coque arrière.
  40. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 40, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 40, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 40, image 3 de 3
    • Passez maintenant au côté droit de l'écran LCD et faites levier avec le médiator à plusieurs endroits le long du côté pour déplacer l'écran LCD vers la gauche.
    • Répétez cette étape et la précédente plusieurs fois, jusqu'à ce que l'écran LCD soit facilement démontable vers la gauche et vers la droite.
  41. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 41, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 41, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 41, image 3 de 3
    • Dans les prochaines étapes, vous ferez glisser un spudger entre l'écran LCD et la plaque de protection en métal pour séparer complètement l'écran LCD de l'adhésif en dessous.
    • Insérez l'extrémité plate d'un spudger entre le châssis du LCD et la plaque de protection en métal.
    • Assurez-vous d'insérer le spudger entre le cadre LCD et la plaque de protection, et non sous la plaque. Faire levier sur la plaque l'endommagerait, car elle est vissée à la coque arrière sous l'écran LCD.
  42. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 42, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 42, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 42, image 3 de 3
    • En commençant en haut à droite de l'appareil, faites glisser le spudger entre le châssis du LCD et la plaque de protection en métal. L'adhésif se décollera au fur et à mesure que vous faites glisser votre outil.
    • L'objectif est de séparer l'adhésif et non de faire levier sur l'écran LCD. Pour cela, maintenez la pointe du spudger aussi bas que possible pour éviter de plier l'écran LCD.
    • Si l'insertion du spudger plie le coin de l'écran LCD, répétez les étapes avec le médiator pour décoller davantage l'adhésif.
    These steps were hard. I was too scared that I was going to brake the LCD. Luckily I got it off! Don’t know how delicate these things are and how much force they can take.
    me to it was hard
  43. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 43, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 43, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 43, image 3 de 3
    • Répétez la procédure précédente en haut de l'écran LCD.
    • Insérez l'extrémité plate du spudger entre le châssis LCD et la plaque de protection en métal et appuyez doucement sur le haut de l'appareil pour décoller l'adhésif.
  44. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 44, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 44, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 44, image 3 de 3
    • Continuez du côté gauche de l'écran LCD : insérez l'extrémité plate du spudger entre l'écran LCD et la plaque de protection et faites-le avancer autant que possible.
    • À ce stade, l'écran LCD doit être décollé de l'adhésif qui le retient. Si ce n'est pas le cas, insérez le spudger sur le côté droit ou en haut pour dégager complètement l'écran LCD.
  45. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 45, image 1 de 1
    • Soulevez l'écran LCD à quelques centimètres de la coque arrière pour vous assurer qu'il est exempt d'adhésif.
    When I did it I found that the adhesive sticking was mainly on the edges, so if you take a spudger and just break that adhesive carefully it will help. Be gentle lifting the lcd as it’s very breakable.
  46. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 46, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 46, image 2 de 2
    • Deux larges bandes d'adhésif relient l'écran LCD aux haut-parleurs.
    • Tout en tenant l'écran LCD d'une main, insérez l'extrémité plate d'un spudger dans l'espace entre l'adhésif et le haut-parleur gauche.
    • Retirez doucement l'écran LCD des haut-parleurs tout en faisant pivoter le spudger vers l'extérieur pour séparer l'adhésif du haut-parleur.
    I recommend removing these two pieces of foam tape prior to loosening and lifting the LCD.
    northstar - Réponse
  47. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 47, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 47, image 2 de 2
    • Insérez l'extrémité plate du spudger dans l'espace entre le haut-parleur droit et l'adhésif du LCD.
    • Tout en retirant l'écran LCD des haut-parleurs, faites pivoter le spudger vers l'extérieur pour élargir l'espace et décoller l'adhésif du haut-parleur.
  48. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 48, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 48, image 2 de 2
    • Retournez l'écran LCD et posez-le sur le dessus de la vitre du panneau frontal.
    • N'essayez pas d'enlever l'écran LCD de l'iPad, car il est toujours connecté par son câble de données.
  49. Remplacement de l'écran LCD de l'iPad Mini GSM, Plaque de protection de l'écran LCD: étape 49, image 1 de 1
    • Retirez les vis suivantes, fixant la plaque de protection de l'écran LCD à la coque arrière de l'iPad :
    • Deux vis cruciformes #00 de 2,6 mm
    • Treize vis cruciformes #00 de 2,6 mm
    • Une vis cruciforme #00 de 1,7 mm supplémentaire sur certains modèles
    At the iPad mini retina Wi-Fi there are only 7 screws.
    sandro - Réponse
    On my iPad Mini (Gen 1 WiFi; A1432), these are not #00 screws, but #000 screws. They're much tinier than the first four screws that held the LCD tabs in place. The #00 driver sorta works, but requires a lot of force to get traction. The #000 driver works like a charm, though.
    volty - Réponse
    On my 1432 there were mixed in 4 tiny #000 screws holding the shield plate aong the right side. Looks like these can be mixed in without consequence as they are shorter anyway
    gfriedman99 - Réponse
    I have a missing plate and screws
    Keah Smith - Réponse
  50. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 50, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 50, image 2 de 2
    • Insérez l'extrémité plate d'un spudger sous la plaque de protection de l'écran LCD, au milieu du côté inférieur de l'iPad.
    • Faites levier avec le spudger pour dégager la plaque des côtés de la coque arrière.
  51. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 51, image 1 de 1
    • Retirez la plaque de protection de l'écran LCD de l'iPad.
    theres a lip on the rear case that prevents you from lifting this straight out, be careful to not bend the plate.
    jfaulks1 - Réponse
    Once the LCD is clear of the shield, wiggle a long plastic spudger up the center between the shield and the battery to gently bend the shield. That will help in getting it away from the sides and make it easier to come out.
    Bill Shannon - Réponse
  52. Remplacement de l'écran LCD de l'iPad Mini GSM, Connecteur de batterie: étape 52, image 1 de 1
    • Retirez les trois vis cruciformes #00 de 1,3 mm fixant le cache du connecteur à la carte mère.
    • Assurez-vous de ne pas substituer ces trois vis par d'autres vis, en particulier les vis qui fixent la plaque de protection de l'écran LCD à la coque arrière de l'iPad. Toute vis légèrement plus longue peut détériorer les trous des vis et endommager irréparablement la carte mère.
    Note: These three screws are smaller than the rest of the screws holding the larger LCD shield although they look similar. If you substitute the larger screws, you will pop a screw bracket which can damage the board on both the mini original and mini 2 retina. I just wrote a blog post about how this happens: http://mendonipadrehab.com/entries/gener...
    jessabethany - Réponse
    Hi jessabethany. Thank you for the warning. I read your blog post and found it to be very informative. Thanks for adding the warning to the step. It will most definitely help others avoid any damage to the logic board. Thanks!
    Walter Galan -
    Be careful: At iPad mini retina Wi-Fi there are thw short and one longer screw! Don't mix them!
    sandro - Réponse
  53. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 53, image 1 de 1
    • Utilisez une pincette pour saisir et retirer de l'iPad le cache du connecteur.
  54. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 54, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 54, image 2 de 2
    • Utilisez un outil d'ouverture en plastique pour retirer délicatement le connecteur de batterie de sa prise sur la carte mère.
    • Soyez très prudent de faire levier seulement sur le connecteur de la batterie et non sur la prise elle-même. Vous risquez autrement de briser complètement le connecteur.
    Make sure you disconnect the battery. If not and ipad is still on you can have problems with the LCD backlight. To fix that problem you have to solder
    Mattis - Réponse
    I may be experiencing the backlight problem you mentioned. What connection needs to be soldered?
    Grillwrecka -
    Have an issue - heard that if you don't disconnect the battery a fuse is blown. I need help to fix the blown fuse.
    Andrew Kivell -
    There is an extensive thread in Answers about iPad mini backlight problems.Th screen stays black after a digitizer replacement.
    jessabethany -
    After unplugging the battery place a guitar pick in-between the two connections.
    While continuing to work on the iPad you may inadvertently cause the two connections to touch.
    Michael Vovaris - Réponse
    Yeah, you need to put the pick in between the connections so the battery doesn't touch the logic board connector and blow a fuse and make your backlight not turn on. You really don't want to have to solder the 2 connections together, especially if you don't know how, like me! I will use your comment's advice when working.
    WolfyHD - Réponse
    I put a piece of cellotape on the contact side of the connector and could happily forget about it while getting on with the rest of the repair.
    Rory Filer - Réponse
  55. Remplacement de l'écran LCD de l'iPad Mini GSM, Écran LCD: étape 55, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM, Écran LCD: étape 55, image 2 de 2
    • Utilisez un outil d'ouverture en plastique pour retirer le connecteur LCD de sa prise sur la carte mère.
    • Ne faites pas levier contre le grand IC à côté du connecteur, vous risqueriez de le casser. Faites délicatement levier sur côté du connecteur comme sur la photo.
    Putting the iPad back together: While plugging the LCD Connector back in, take your time finding the socket on the logic board. Do no use pressure until you are certain it is seated properly. Trust me, if you take your time you will know its seated correctly.
    Does it shares the same shape/size of the LCD connector between the ipad mini wifi only WHITE and the other one ipad mini 32gb BLACK?
    muhammadbukhari10 - Réponse
  56. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 56, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 56, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 56, image 3 de 3
    • L'écran LCD est toujours connecté au reste de l'iPad par deux larges bandes de ruban adhésif qui passent de l'intérieur de la coque arrière à la partie avant du cadre LCD.
    • Tout en tenant l'écran LCD d'une seule main, insérez l'extrémité plate d'un spudger entre l'écran LCD et la bande adhésive sur le côté droit de l'iPad.
    • Faites glisser le spudger vers l'extérieur, en décollant la bande adhésive et en soulevant doucement l'écran LCD pour les décoller.
    • Il peut être utile de faire pivoter le spudger, pour agrandir l'écart et décoller l'écran LCD de la bande adhésive.
    Removing this tape and such to take the LCD off completely is unneccessary when replacing just the glass and digitizer, the digitizer cable is easily removed without further work to the LCD
    Dave Davidson - Réponse
    When this tape damage, how we can take a new?
    Muhammed Kilic - Réponse
    When this tape are damage, how we can order and take a new one?
    Following from Nick H’s comment about LCD removal being unnecessary - I tried that first and got my broken glass OUT of the assembly by threading it thru a limited space beneath the LCD. Later when trying to reseat the digitizer connector I gave up and removed the LCD anyhow. Not that much extra work but a LOT easier to install the digitizer and reseat the connector without having to navigate around the LCD and its cable. Removal of the tape holding the LCD was easy - there are two short lengths of rubber or foam along the bottom edge of the LCD that faces the outside world. Remove those(save them) and then _carefully_ peel up the tape; I saw some metallic looking residue underneath. Later when re-assembling everything, I put the tape back and then those two short lengths of foam.
    on mine this tape was already loose.
    jfaulks1 - Réponse
  57. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 57, image 1 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 57, image 2 de 3 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 57, image 3 de 3
    • Tout en tenant l'écran LCD d'une main, passez au côté gauche de l'iPad et répétez la procédure de l'étape précédente pour décoller le deuxième morceau de bande adhésive.
    • Insérez l'extrémité plate d'un spudger entre le cadre LCD et la bande adhésif, et faites-le glisser vers l'extérieur tout en soulevant doucement l'écran LCD.
  58. Remplacement de l'écran LCD de l'iPad Mini GSM: étape 58, image 1 de 2 Remplacement de l'écran LCD de l'iPad Mini GSM: étape 58, image 2 de 2
    • Soulevez et retirez de l'iPad mini l'écran LCD.
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
15 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Andrew Optimus Goldheart
Membre depuis le 10/17/09
509 321 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
19 996 tutoriels rédigés
1 commentaire de tutoriel
Very helpful! Thanks so much. I started to change the broken screen with the new screen I ordered, but ended up screwing up the LCD from overheating it with a floor heater when I tried to detach it, because I didn’t find this guide before I did that haha. But afterwards I ordered and replaced the LCD with the help of your guide, and now I have a working device again! WOAH feels great!! THANK YOU!!!
Gina Romo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 17,465
