Introduction
Follow this guide to learn how to replace the display assembly on your Samsung Galaxy S6 Edge.
Use this guide if you are replacing the display assembly only. If your replacement part comes with a frame, follow this guide instead.
If the frame is damaged or bent, it's important to replace it, or else the new screen may not mount correctly and can suffer damage from uneven pressure.
The process of separating the display from the frame usually destroys the display, so don't follow this guide unless you intend to replace the display.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
Outils
If your replacement part looks like the first image, follow the display assembly and frame replacement guide.
If your replacement part looks like the second image, follow the display assembly replacement guide.
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone.
Press to eject the SIM card tray.
Remove the SIM card tray from the phone.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove the thirteen 3.3 mm Phillips #00 screws from the midframe.
Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
Prepare an iOpener and apply to the left edge of the phone for about a minute.
You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
The display edges are secured by strips of strong foam adhesive.
Strong double-sided tape covers the entire copper surface.
Cut very carefully near the "recent" and "back" capacitive buttons near the bottom of the display. These are adhered to the display and are very easy to tear.
12 autre(s) ont terminé cette réparation.
